Date/Time: Wed, 15 Jan 2025 16:25:58 +0000
numberbars highlight non-zero with column 1 extension line not working correctly
View Count: 839
[2017-07-17 14:37:29]
Mistic - Posts: 76
Numberbars highlight non-zero column 1 extension line should only be working at the high or low of the numberbar. I've attached an image of what it looks like on my end. Now if you go to studies and just click ok, it'll correct all of them. so not really sure what the problem is. didn't circle all of them on the image, just appears the extension line isn't disappearing when non-zero at high or low becomes a zero on developing/developed bars
Date Time Of Last Edit: 2017-07-17 14:42:33
Private File
[2017-07-17 15:35:21]
Make sure you are running the latest prerelease. Currently you are not.
This will be solved in the next release.
[2017-07-17 16:25:35]
Mistic - Posts: 76
I had problems with the latest pre-release with cpu exception errors, already notified SC and appears fixed now, just upgraded back to v1584.
ok thanks
one more thing, Could the extension lines be shown on top of all OHLC study lines? posting a chart image of the low line shown but the extension line is behind it. I have numberbars as the first study listed.
Private File
[2017-07-19 23:45:56]
We can make the extension lines display above the Numbers Bars themselves. But this is all. We will add an option for that.
You will want the Numbers Bars study to be the last study listed. Actually tell us if that resolves the problem.
Date Time Of Last Edit: 2017-07-19 23:46:36
[2017-07-20 00:32:16]
Mistic - Posts: 76
Having Numberbars listed last did resolve it. Thanks. Attached image of it.
Did the extension lines get fixed? upgraded to v1586 earlier today. didn't see it written on what's new notes if it was.
Private File
[2017-07-20 13:18:55]
Yes.
