Date/Time: Wed, 15 Jan 2025 15:46:51 +0000
New starter help request
View Count: 820
[2017-07-17 14:36:14] |
User727034 - Posts: 21 |
Is there any tutorials in setting up SC. I've been reading stuff for days now and I managed to install SC but I am stuck on where to find the "up to 2 week real time data feed" option to select. Because of all the material out there (and it is seriously daunting for an unfamiliar reader) i expect that setting up the platform data feed could take some time. Is there any video tutorials out there that provide the idiots guide to getting the program up and running? |
[2017-07-17 15:46:58] |
Refer to: Getting Started, Opening Charts and Basic Trading where to find the "up to 2 week real time data feed" option to select. In regards to this, you are referring to the Sierra Chart Exchange Data Feed which we recommend avoid using now:Sierra Chart Exchange Data Feed Just use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-17 15:47:49
