Date/Time: Wed, 15 Jan 2025 15:23:37 +0000
chart calculator (alt + 2) count TD (trading days?) wrong?
View Count: 1013
[2017-07-17 08:22:29] |
BlueWhisper - Posts: 7 |
Hi, testing out sierra charts. was using the chart calculator (alt + 2) tool and cant help but notice it counts TD (trading days?) wrong? example i dragged it from 15 June to 30 June. why does it show 15 TD (includes both weekends as trading days?). is this correct, or a bug? other software I used will exclude weekends... thanks! EDIT: for example, on tradingview if you use their counting tool, it will say 11 bars, 15 days. is similar thing possible in Sierra? Date Time Of Last Edit: 2017-07-17 08:52:12
[2017-07-17 08:25:32] |
Or is there another tool for counting trading bars (based on time frame)? like telling me how many 30 min bars fr point A to B (instead of the total time units 2hr 30 min I prefer it to say 5 bars). Thanks
[2017-07-17 15:50:06] |
TD is Time Difference. What you want is Number of Bars. You can enable that for the Chart Calculator tool. Refer to: Chart Drawing Tools: Drawing Tool Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
