Date/Time: Wed, 15 Jan 2025 15:23:01 +0000
Retrieve Sierra
View Count: 734
[2017-07-16 22:09:25] |
narcese - Posts: 58 |
I am getting this message when clicking on Icon: Problem with Shortcut The item "sierra chart.exe" that this shortcut refers to has been changed or moved, so this shortcut will no longer work properly. Do you want to delete this shortcut? Any thoughts on solution? |
[2017-07-17 01:18:16] |
Yes delete the shortcut, and set up a new one to where SierraChart.exe is installed to on your system. Or when Sierra Chart is running select Global Settings >> Create Desktop Shortcut. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
