Date/Time: Wed, 15 Jan 2025 15:30:18 +0000
MIRROR TRADING
View Count: 1344
[2017-07-16 02:50:28] |
User587036 - Posts: 3 |
Hi, I'd like to know if is it possible to trade "mirror trading" using sierra. Example: Account #1 (PERSON1) Account #2 (PERSON2) When I place an order on Account #1, automatically the same order is placed on Account #2 Thank you! |
[2017-07-17 01:11:54] |
No, this is not directly supported within Sierra Chart. But check with the external Trading service you plan to use with Sierra Chart and see if they offer this capability. They might. Longer-term we do plan to develop this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-17 11:33:12] |
GM, Tks for your reply! Pls, what you mean by "external Trading service"? Do you know who offers this service? Best! |
[2017-07-17 15:39:18] |
Would be best to contact the different supported services about this. Refer to: Supported Data and Trading Services Have a look at CTS and Interactive Brokers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
