Date/Time: Wed, 15 Jan 2025 15:19:20 +0000
Server side bracket/oco under AMP/CQG - how to test?
View Count: 1517
[2017-07-15 17:01:30] |
User305145 - Posts: 38 |
Hi, Is there a way I can test and make sure the "held at server side" is functioning as it should? /Martin |
[2017-07-15 17:57:30] |
Also, are there any conditions under which an auto placed protective stop upon order fill would somehow get cancelled? E.g. my computer, internet and/or SC platform fails? |
[2017-07-15 18:04:25] |
Noticed from a prev post: You say: "Server-side bracket orders are not supported with CQG FIX. They are managed client-side." Server-side bracket orders with CQG FIX | Post: 58159 Is this old info or did I miss smt? |
[2017-07-17 01:09:54] |
Is there a way I can test and make sure the "held at server side" is functioning as it should? Attached Orders: Management of Attached Orders when Trading Service Supports Server Side Bracket Orders Also, are there any conditions under which an auto placed protective stop upon order fill would somehow get cancelled? Not sure exactly what you mean. When a Stop order is filled, why would it be canceled?Server-side Bracket orders are supported with CQG FIX and you are looking at old information. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-17 01:10:11
[2017-07-17 11:52:57] |
Ok When I am filled on a position, I wish to have a protective stop loss order placed automatically (here "attached order" functionality w a simple stop and no target seems reasonable(?)). My concern is that this protective stop loss order might get cancelled when I'm still in a position (due to e.g. platform/pc/internet fail) Is such an order held at server? /Martin |
[2017-07-17 12:31:27] |
You write: "If you have just a single target or a single stop and not a corresponding stop or target, then there is no OCO group." Attached Orders: Management of Attached Orders when Trading Service Supports Server Side Bracket Orders Does this have any implications as to whether my auto placed protective stop loss order is held at server or not? |
[2017-07-17 12:53:25] |
In response to post #5, refer to: Attached Orders: General Management of Attached Orders Attached Orders: Management of Attached Orders when Trading Service Supports Server Side Bracket Orders An attached Order will be canceled at the end of the day if it is a Day order. And not a Good till Canceled order. Does this have any implications as to whether my auto placed protective stop loss order is held at server or not? Attached Orders: General Management of Attached Orders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-17 12:53:53
