Date/Time: Wed, 15 Jan 2025 15:45:11 +0000
How to see bar index while debugging
View Count: 977
[2017-07-14 18:08:39] |
DabbaDo - Posts: 148 |
I often need the current bar index while debugging. Currently I add a study that "charts" the index and I can see its value in the Tools Value Window as I move the Chart Values Tool. Is there an easier way? It would be really nice if it displayed right under the Y value at the top of the TVW. Cheers, Dale |
[2017-07-14 18:12:56] |
It sounds like creating your own study is the best thing to do.
[2017-07-16 17:21:46] |
Cavalry3162 - Posts: 523 |
maybe use the "Text Display for Study" study? it can print a study value onto the chart at the position you desire... i use it to print the value of the relative volume study as text in my chart, see attachement.
2017-07-16_13-20-46.png / V - Attached On 2017-07-16 17:21:42 UTC - Size: 62.65 KB - 303 views |
