Date/Time: Wed, 15 Jan 2025 15:48:47 +0000
ATBB Chart Graphics
View Count: 820
[2017-07-14 17:27:18] |
User832512 - Posts: 22 |
Is there a way to CONNECT the individual trade results with dotted lines on the ATBB back testing chart results?
[2017-07-14 23:17:38] |
So you are referring to Auto Trade Bar-based Back Testing. You can do this. Refer to: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart You will need to enable the Global Settings >> Chart Trade Settings >> Display Entry/Exit Connect Lines option. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-14 23:18:07
