Date/Time: Wed, 15 Jan 2025 15:31:40 +0000
Extended DOM
View Count: 743
[2017-07-14 12:44:38]
User690267 - Posts: 13
I am requiring to set up an extended DOM similar to the image i have attached, though i use the DOM graph on chart option.
Currently the DOM shows the normal 10 each side of price.
I am using CTS T4 for data.
Thank you
imageDEsfN6tWsAA1jHB-2.jpg / V - Attached On 2017-07-14 12:42:44 UTC - Size: 12.81 KB - 265 views
[2017-07-14 17:26:37]
We do not think there is any more than 10 levels of depth available when using CTS T4.
So at most you would see 10 levels.
[2017-07-14 17:27:53]
Do you know which data provider can provide greater than 10 levels
[2017-07-14 18:01:32]
CQG does. Refer to:
CQG Trading Platform Service
