Date/Time: Wed, 15 Jan 2025 15:43:41 +0000
TD Ameritrade
View Count: 1172
[2017-07-13 21:46:00] |
narcese - Posts: 58 |
I have an account with TD Ameritrade and they confirmed that their data is compatible with Sierra Charts. I have a user name and password, however, there is a streamer address override request. Can you clarify the process for accessing data from TD Ameritrade? Thanks, Nick |
[2017-07-14 02:18:02] |
Follow the step-by-step instructions here: https://www.sierrachart.com/index.php?page=doc/AmeriTrade.php#SetupInstructions Do not set the Streamer Address Override. We will update the documentation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
