Date/Time: Wed, 15 Jan 2025 15:28:07 +0000
Error when opening studies window
View Count: 683
[2017-07-13 18:29:39] |
User409029 - Posts: 5 |
Whenever I open the studies window the error log opens up and says the following: "Failed to get the Advanced Custom Study function address scsf_RevereseOrderCopyofBaseGraph in SierraChartStudies.dll Error: Windows error code 127: The specified procedure could not be found" Please help. Thanks Ned |
[2017-07-13 18:43:08] |
We want you to update Sierra Chart again. Update with Help >> Download Prerelease. Here are instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-13 19:33:49] |
Thank you. It worked like a charm!
