Date/Time: Wed, 15 Jan 2025 15:40:10 +0000
unusual wide axis
View Count: 813
[2017-07-13 15:23:45]
Cavalry3162 - Posts: 523
Hello Support,
for certain symbols, like UVXY.bz as an example, the axis appears unusual wide (see screenshot). that's wasting a lot of screen real estate, especially if you're using a lot of small charts as in this example..
it would be great if you'd take a look at it.
thanks,
Andreas
image2017-07-13_11-17-58.png / V - Attached On 2017-07-13 15:23:36 UTC - Size: 8.48 KB - 232 views
[2017-07-13 15:42:49]
This is not based upon the symbol.
Do you have Trade >> Show Market Data Columns enabled?
[2017-07-13 15:47:07]
i do not and it is symbol based.. same chart, different symbol: https://www.screencast.com/t/fhHIeDUNiq
[2017-07-13 16:00:49]
When you scroll all the way to the left of the chart, you can see the higher values of that symbol.
This is the reason why the right side scale is wider.
What you need to do is reduce the amount of data in the chart through Chart >> Chart Settings >> Days to Load.
[2017-07-13 16:03:42]
you probably dont get my point... i am talking about that empty space right of the axis...
see screenshot marked with a red box..
Date Time Of Last Edit: 2017-07-13 16:04:31
image2017-07-13_12-01-54.png / V - Attached On 2017-07-13 16:03:38 UTC - Size: 15.32 KB - 258 views
[2017-07-13 16:54:07]
Yes we do.
Scroll the chart all the way over to the far left side. Those large numbers are the reason why you see the wider scale on the Values Scale.
Date Time Of Last Edit: 2017-07-13 16:54:13
[2017-07-13 16:56:06]
aaaaaaah.. got it.. thanks for pointing that out!
