Date/Time: Wed, 15 Jan 2025 16:07:28 +0000
Study Subgraphs Reference not plotting well depending on the size of the window
View Count: 700
[2017-07-13 10:43:45] |
User252419 - Posts: 235 |
Using Study Subgraphs Reference from Line 0 to Ask/Bid Volume, it doesn't plot well. Is there any way to solve it? WRONG: http://www.sierrachart.com/image.php?Image=1499942229876.png WRONG but better: http://www.sierrachart.com/image.php?Image=1499942455407.png WELL: http://www.sierrachart.com/image.php?Image=1499942496372.png Thank you |
[2017-07-14 02:12:50] |
We really do not know what your question is.
[2017-07-14 09:28:42] |
This is my question: How can I see the red background of the Bid Volume going from 0 Line to Bid Volume, without exceeding it? Right now: It goes from 0 Line to above Bid Volume depending on how I scale the window. I want the red background to go from 0 Line to Bid Volume, without exceeding Bid Volume. Green background is plotting well, it goes from 0 Line to Ask Volume, without exceeding. Thank you Date Time Of Last Edit: 2017-07-19 08:27:25
[2017-07-19 08:26:42] |
Do you understand my question? Thank you |
[2017-07-20 19:08:50] |
We think we understand what you are asking about now. Make sure that each and every study in Chart Region 2 has the Scale Range set to Automatic. Refer to: Chart Scale and Scale Adjusting: Opening the Scale Settings Window For a Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
