Date/Time: Mon, 10 Mar 2025 10:43:37 +0000
Time Range Highlight add Feature
View Count: 1454
[2017-07-13 05:49:19] |
User790704 - Posts: 1 |
Can you add the High and Low to the Time Range Highlight study, so it creates a High/Low Session Box. Thanks, Rainer |
[2017-07-13 05:58:17] |
For this you will want to use the High/Low for Time Period Study: High/Low for Time Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-19 15:11:01] |
User641398 - Posts: 19 |
I'm trying to set up a High Low range session Box but I don't understand why the lines don't go on the highs and lows
[2022-03-19 17:34:12] |
I don't understand why in this chart with the same settings it draws correctly the box while in the right one it does not. In addition if I move to H1 it is not displayed correctly. |
[2022-03-23 16:05:34] |
John - SC Support - Posts: 38516 |
Please attach a chartbook that has the chart that is not working correctly for you and we will take a look. Follow these instructions to get us a chart: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-23 17:17:04] |
Here it is
[2022-03-23 22:07:30] |
You need to use the Draw Style of Transparent Fill Rectangle Top/Bottom. Refer to the information here: Chart Studies: Transparent Fill Rectangle Top (ACSIL: DRAWSTYLE_TRANSPARENT_FILL_RECTANGLE_TOP) and Transparent Fill Rectangle Bottom (ACSIL: DRAWSTYLE_TRANSPARENT_FILL_RECTANGLE_BOTTOM) Otherwise, you get that tail as the data does not immediately drop to 0 and it is showing you that information. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-24 06:25:49] |
solved thanks
