Date/Time: Wed, 15 Jan 2025 15:25:52 +0000
DOM lines and price alerts
View Count: 1100
[2017-07-12 23:29:18] |
User375599 - Posts: 5 |
Is there any easier way to draw levels on the DOM or to add a single click price alert onto the DOM? Creating a level, and adding an alert to it seems to take too long Idealy I'd love a hotkey or somewhere to click on the dom which makes a noise when that price gets hit |
[2017-07-13 05:50:06] |
We recommend using Symbol Alerts: Alerts Manager: Symbol Alerts Or you could use a normal chart and draw a Horizontal Line and set an alert on that. Refer to: Chart Drawing Tools: Horizontal Line | Horizontal Ray | Horizonal Line Non-Extended | Vertical Line Chart Drawing Tools: Chart Drawing Alerts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
