Date/Time: Wed, 15 Jan 2025 15:20:07 +0000
Period OHLC Variable
View Count: 902
[2017-07-12 19:09:56]
User681267 - Posts: 16
How do I stop the Period OHLC Variable from drawing in a "stair step" style? The Weekly and Daily are fine but the Variable has to be constantly refreshed to keep a horizontal line.
imagePeriod OHLC.PNG / V - Attached On 2017-07-12 19:08:02 UTC - Size: 62.65 KB - 280 views
imagePeriod OHLC 2.PNG / V - Attached On 2017-07-12 19:08:26 UTC - Size: 71.73 KB - 267 views
[2017-07-13 06:04:22]
We see what you are saying. When the OHLC lines are based on the current period, as the High, Low, Close change, the lines are only updated as of the bars where those changes occur in real-time or during a replay.
[2017-07-13 06:23:10]
So does your reply mean that that's just the way it is and no changes will be made?
[2017-07-13 22:51:31]
We will look into this. And see if we can implement a quick solution. Although it will make the study less efficient.
Date Time Of Last Edit: 2017-07-13 22:51:45
[2017-07-14 05:41:50]
We have implemented a solution to this. This will be out in the next release.
