Date/Time: Wed, 15 Jan 2025 16:21:33 +0000
Overnight position on Liffe
View Count: 792
[2017-07-12 10:26:08] |
User357295 - Posts: 76 |
The system is not able to keep overnight positions on Liffe ( only). Each time I keep overnight positions on liffe, the system does not catch it even if my statement( produced by FCM) shows that overnight position. Please advice |
[2017-07-12 14:15:22] |
So you are saying you have a current Position in a LIFFE contract but you do not see that Position listed in the Trade >> Trade Orders and Positions >> Positions list? If so, contact your broker about this. This would be an issue on the CQG side. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-12 14:19:54] |
What I'm saying is I had an overnight position on both Eurex & Liffe, the one on Eurex appears this morning but not the liffe's . This is not the first time such thing happens, I would appreciate if you could take a look into it.
[2017-07-12 14:51:04] |
We have no ability to check something like this. You need to contact your broker about it and they would need to contact CQG if necessary. Refer to: https://www.sierrachart.com/index.php?page=doc/TradeStatusWindows.html#IncorrectlyReportedTradePosition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-12 14:51:17
