Date/Time: Wed, 15 Jan 2025 16:10:45 +0000
Copy chart drawings from chart # issue
View Count: 674
[2017-07-12 06:00:40] |
Dom7364 - Posts: 257 |
Using the option "Copy chart drawings from chart" in "Chart Settings", "Advanced settings 2" is not working anymore. I have not changed anything and it was working as it should, but has stopped doing so. Perhaps is there something in the new update (have version 1583)? |
[2017-07-12 14:53:52] |
Nothing has changed with this functionality and it definitely works properly. Refer to: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) Chart Settings: What to Do If Chart Drawings Do Not Copy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-12 14:57:44] |
Anything I could try to troubleshoot? Honest; I am not making it up..
[2017-07-12 15:04:37] |
Yes, the instructions explain this. Here they are again: Chart Settings: What to Do If Chart Drawings Do Not Copy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
