Date/Time: Wed, 15 Jan 2025 16:15:32 +0000
Volume Profile - Ticks Per Volume Bar...
View Count: 1363
[2017-07-12 00:24:02] |
User80732 - Posts: 26 |
How can I configure the ticks per bar to be less than 5??... For some reason regardless what I try with various configurations/time frames I'm unable to change the ticks per volume bar smaller than 5. Thanks! |
Ticks Per Bar.PNG / V - Attached On 2017-07-12 00:23:19 UTC - Size: 116.81 KB - 365 views Attachment Deleted. |
[2017-07-12 01:08:58] |
User103861 - Posts: 42 |
I think you have to change the setting under "Chart Settings" first. On the Main Settings page under Chart Settings you can set the value to whatever you want under "Volume at Price Mult". I set mine to 1.
[2017-07-12 03:03:35] |
You do need to adjust the Volume at Price Multiplier in Chart >> Chart Settings. This is explained here: Volume By Price Study: Ticks Per Volume Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
