Date/Time: Wed, 15 Jan 2025 16:10:35 +0000
Seeing High, Low, Close, and Open Values of a Candlestick?
View Count: 1543
[2017-07-11 20:59:05] |
User585845 - Posts: 17 |
I am looking a daily chart and putting my cursor over a candlestick and do not see the high, low, open, and close values anywhere on the chart. How do I turn this feature on so that every time I place my cursor on a candlestick I can immediately see these values on the top of the chart? Thanks for your help.
[2017-07-11 21:21:22] |
cmet - Posts: 580 |
Top Menu Window > Show Compact Tool Values Window You have to click to get it to show. |
[2017-07-12 03:04:18] |
Refer to the detailed documentation here about this: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
