Date/Time: Wed, 15 Jan 2025 16:19:30 +0000
Best option for oil real time data?
View Count: 905
[2017-07-11 16:32:24]
ssangha84 - Posts: 124
I already have the Sierra Chart package 5. And I guess it does not come with real time data. I was wondering what the best option would be for me to purchase real time data. I am only interested in trading Oil. Also, with the purchase of the real time data, would I be able to demo trade?
[2017-07-11 16:48:03]
We think the best thing to do is to use the Alternative to Futures Data. Refer to:
Is Historical and Real-time Futures Data Included?: Alternative to Futures Data
Your Sierra Chart Service Package already includes this.
The symbols are in File >> Find Symbol >> CFD.
Date Time Of Last Edit: 2017-07-11 16:48:38
[2017-07-11 17:02:40]
OK. I'm trying to set it up so I can activate the real time data on my platform. The instructions can get very confusing. What is the fastest way to activate it?
[2017-07-11 17:28:40]
There is nothing to activate if you just use the CFD data.
Refer to:
Sierra Chart Real Time and Historical Forex and CFD Data Service
Real-time futures data is too expensive and we do not recommend it.
[2017-07-11 17:39:26]
Is there a number I can call to speak with you guys? That link is saying that real time data is available. I want to demo trade oil in real time so what would be the best way to do this?
[2017-07-11 17:44:23]
Also, I am getting an error when I go to SC Data-All Services. It is saying it is connected, but then it says download failed. Is this not included with the package 5?
[2017-07-11 18:00:11]
The answer to this question is yes. Refer to:
Trade Simulation
Yes, real-time Forex and CFD data is included.
Select File>> Find Symbol >> CFD.
Choose USOil from the list and press Open Intraday Chart.
Provide a copy of the Message Log by following these instructions:
If necessary we will call, but you should not be having any difficulty.
[2017-07-11 18:07:54]
Here is the message log:
Reading Internal Order ID file. | 2017-07-11 09:33:23
Reading Trade Orders file. | 2017-07-11 09:33:23
Reading Trade Positions file. | 2017-07-11 09:33:23
Listening on UDP port 22903. | 2017-07-11 09:33:23
Software version: 1568 | 2017-07-11 09:33:23
Uses New Spreadsheets | 2017-07-11 09:33:23
Usage end date: 2017-07-27 | 2017-07-11 09:33:23
Enabled for: Advanced Features. | 2017-07-11 09:33:23
Enabled for: Advanced Features 2. | 2017-07-11 09:33:23
Enabled for: Sierra Chart Historical Data Service. | 2017-07-11 09:33:23
Allow Support for Sierra Chart Data Feeds is enabled. | 2017-07-11 09:33:23
Current selected Data/Trading service: SC Data - All Services | 2017-07-11 09:33:23
Chart Update Interval: 500 | 2017-07-11 09:33:23
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-07-11 09:33:23
2017-07-11 06:33:27 Local computer time | 2017-07-11 09:33:23
2017-07-11 13:33:27 Local computer time in UTC | 2017-07-11 09:33:23
2017-07-11 09:33:27 Local computer time in SC Time Zone | 2017-07-11 09:33:23
2017-07-11 13:33:25 Server time in UTC | 2017-07-11 09:33:23
Local computer UTC time and Server UTC time difference: 1 seconds. | 2017-07-11 09:33:23
Program path: C:\SierraChart\ | 2017-07-11 09:33:23
Data Files path: C:\SierraChart\Data\ | 2017-07-11 09:33:23
OS Version Number: 6.2 | 2017-07-11 09:33:23
Locale Setting: C | 2017-07-11 09:33:23
Checking for new symbol settings for service code scdataallservices | 2017-07-11 09:33:23
HTTPS connection to www.sierrachart.com:443 (3) | Creating socket. Using TLS 1.2. | 2017-07-11 09:33:23
HTTPS connection to www.sierrachart.com:443 (3) | Connecting to IP: 204.15.192.108. | 2017-07-11 09:33:23
Symbol settings are up-to-date for scdataallservices | 2017-07-11 09:33:30
SC Data - All Services | Connected to data server. | 2017-07-11 14:05:13
SC Data - All Services | Starting real-time market data updates for: GCLQ7. ID: 1 | 2017-07-11 14:05:13
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: GCLQ7 | 2017-07-11 14:05:13
SC Data - All Services | Requesting security definition data for: GCLQ7. ID: 1 | 2017-07-11 14:05:13
Intraday data recording state for symbol GCLQ7 is set to download 'Pending'. | 2017-07-11 14:05:13
Delaying start of download for GCLQ7 | 2017-07-11 14:05:13
Requesting market depth updates for: GCLQ7 if supported. | 2017-07-11 14:05:18
HD Request # 14 | Downloading Intraday chart data for GCLQ7 to the file GCLQ7.scid. Service: scdataallservices | 2017-07-11 14:05:19
HD Request # 14 | Download start date-time: 2017-07-11 14:04:11.000 | 2017-07-11 14:05:19
HD Request # 14 | Error downloading historical Intraday data for GCLQ7. The futures symbol format is invalid. The year must be 2 digits. | 2017-07-11 14:05:19
HD Request # 14 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCLQ7 | 2017-07-11 14:05:19
HD Request # 14 | Intraday download COMPLETE for GCLQ7. Completion time: 0s. Unique request ID: 13 | 2017-07-11 14:05:19
Removed historical data download ID 13 | 2017-07-11 14:05:19
Real-time Intraday chart data file updates started for GCLQ7 | 2017-07-11 14:05:19
Opened cached Intraday file: C:\SierraChart\Data\GCLQ7.scid | 2017-07-11 14:05:19
Intraday chart data file opened for GCLQ7 | 2017-07-11 14:05:19
Date Time Of Last Edit: 2017-07-11 18:50:42
[2017-07-11 18:52:19]
We see what the problem is. GCLQ7 is an OEC/Gain Capital symbol.
You need to use the symbols listed in File >> Find Symbol for SC Data - All Services. It will be CLQ17.
[2017-07-11 18:59:00]
OK that worked. Is there a reason for the different symbol?
[2017-07-11 19:03:55]
Yes. Each Data and Trading service uses different symbols.
Gain Capital simply uses different symbols.
Date Time Of Last Edit: 2017-07-11 19:04:14
[2017-07-11 19:08:00]
It is looking like this will not be available to watch in real time?
[2017-07-11 19:14:15]
No. For real-time crude oil data, use the CFD symbol we explain in post #7 above.
If you do not have a funded futures trading account, the NYMEX futures cost will be about 125 USD a month.
Date Time Of Last Edit: 2017-07-11 19:14:22
