Date/Time: Wed, 15 Jan 2025 16:01:37 +0000
Market Stats
View Count: 632
[2017-07-11 15:36:19] |
User39448 - Posts: 11 |
My Market Stats will only function under Global Time Zone and not under any other time zone any longer.
[2017-07-11 17:20:25] |
Check the Session Times in the chart. Refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Incorrect Chart and Session Times Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-11 17:38:26] |
Issue Resolved. Thank You.
