Date/Time: Sun, 24 Nov 2024 00:00:10 +0000
Can I draw a line on one chart and have it appear on another?
View Count: 1305
[2013-08-29 22:04:07] |
Allan Stevenson - Posts: 9 |
Say I draw a line on a daily ES chart and want the line to appear on a TPO ES chart? Or do I need to draw it twice? thanks |
[2013-08-29 22:46:45] |
Yes. This is explained here: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#AutomaticallyCopy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
