Date/Time: Wed, 15 Jan 2025 16:19:57 +0000
Volume by Price (VbP)
View Count: 669
[2017-07-11 08:07:55] |
User134797 - Posts: 52 |
Hi All, In the settings and inputs tab of Volume by Price (VbP). You have input name: Display Volume in Bars(In:46) I change the Input value: to "Ask Volume Bid Volume % of tolale Volume". Question: Can I create an alert on the input value "Ask Volume Bid Volume % of tolale Volume". Example 1): if B%=100 then alert, Example 2): if B%=90 and A%10 then alert, Regards, Iwan |
[2017-07-11 16:44:02] |
No, this data is not accessible by Simple Alert Formulas.
