Date/Time: Wed, 15 Jan 2025 13:08:02 +0000
"Volume Weighted Average Price - Rolling" resets on Sundays.
View Count: 1874
[2017-07-11 07:18:53]
Sporken - Posts: 82
with v1580 but present in prior versions as well.
Symbol anything continuously trading, so GBPUSD or ESU17 for example. The price of the VWAP is continuous from day to day, except from Friday to Monday. Is this correct?
Study Inputs:
Input Data - Last
Base on Underlying Data "Yes"
Time Period Type "Days-24 hour period"
Time Period Length "1"
Number of Days to Calculate "1234"
Exclude Weekends in Date Look Back "No" (or "Yes")
Minimum Required Time Period as Percent "0"
[2017-07-11 17:07:16]
This study does not reset.
If there is no data or missing data on Friday, Saturday, Sunday then for bars in the chart referencing those time periods, then they will be referencing no data at all.
You probably will want to increase this percentage:
Date Time Of Last Edit: 2017-07-11 17:07:31
[2017-07-29 19:58:57]
Sporken - Posts: 82
Increasing "Minimum Required Time Period as Percent" was ineffective because I am setting "Time Period Length" to 1. This means GetIndexForStartofDayPeriodForDaysBack is called with NumDaysToInclude=1 so the function returns without iterating. MinimumRequiredTimePeriodInDayAsPercent is unreferenced.
This is the code that causes the issue. In scsf_RollingVolumeWeightedAveragePrice in studies3.cpp:758
else if (PeriodType == 1) // Days - 24 hour periods
  SCDateTime CurrentPeriodStartDateTime = sc.BaseDateTimeIn[Index] - 1 * DAYS + 1 * SECONDS;
  r_FirstIndexIncluded = sc.GetContainingIndexForSCDateTime(sc.ChartNumber, CurrentPeriodStartDateTime);
I propose the following amendment for your consideration
  if (ExcludeWeekendInDateCalc.GetYesNo() &&
    ((sc.BaseDateTimeIn[Index].GetDayOfWeek() == SUNDAY) || (sc.BaseDateTimeIn[Index].GetDayOfWeek() == MONDAY)))
    CurrentPeriodStartDateTime = sc.BaseDateTimeIn[Index] - (3 * DAYS) + (1 * SECONDS);
This appears to correct the discontinuity on my 5min and hourly charts on both futures and forex. I also tested increasing "Time Period Length" and it appeared to be ok.
This behaviour/code is also seen on "Moving Average - Rolling High Accuracy"
A better fix might be to amend GetIndexForStartofDayPeriodForDaysBack and eliminate the sc.BaseDateTimeIn[Index] - 1 * DAYS + 1 * SECONDS calculation entirely.
I'm not very familiar with the code so there may be other ways to approach this.
Date Time Of Last Edit: 2017-07-29 20:04:49
[2017-07-31 05:05:14]
We will look this over and see what is the best solution.
