Date/Time: Wed, 15 Jan 2025 15:31:36 +0000
Function to calculate on subgraph close.
View Count: 682
[2017-07-11 02:11:12] |
Neo - Posts: 198 |
Using sc.GetStudyArrayUsingID, I only want to perform a calculation on a fully completed subgraph. Is there any ACSIL documentation for this? |
[2017-07-11 03:15:37] |
We are not understanding the question. Just use whatever data you want in the study array. You can ignore the last element if you want. There does not need to be any documentation for this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
