Date/Time: Wed, 15 Jan 2025 15:55:51 +0000
tick data
View Count: 994
[2017-07-10 21:37:37] |
dtl-saw - Posts: 79 |
i thought that by disabling "DTS->Allow support for Sierra Chart Data Feeds" that I would bypass the SC data servers and pull the data directly from the broker service but i don't think that's what's happening. i'm comparing CTS-T4 with CQG on a tick by tick basis using cumulative delta volume study in SC. i "edit->delete all data and download" for both services. they have different symbol names so i delete the data and download for both. When i compare them using cumulative delta volume they end up being identical. i would have expected some difference since i've seen big (huge) differences before using another software charting program so i know that CQG filters some of the tick volume. can you confirm that my procedure for bypassing the SC data server is correct and that i should be pulling historical data only from CTS-T4 and CQG? or if not please recommend the procedure for doing this. |
[2017-07-11 04:11:25] |
so i know that CQG filters some of the tick volume. No, this is not the case.We would expect there to be a match. You cannot bypass the Sierra Chart historical data, when using CQG or for expired contracts in the case of CTS. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-11 16:17:51] |
thanks for the clarification one last question about this just to make sure i understand is the real time data that i'm receiving when using a CQG trade service come from CQG directly or the SC data server and also how about CTS-T4 does the real time data when using CTS-T4 trade service come from CTS-T4 directly or the SC data server? thanks |
[2017-07-11 16:50:09] |
The real-time data comes from CQG. When using CTS the real-time data will come from CTS unless you are using the Sierra Chart Exchange Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
