Date/Time: Wed, 15 Jan 2025 15:19:58 +0000
User Question
View Count: 646
[2017-07-10 20:38:10] |
Sierra Chart - Max - Posts: 5778 |
Does your service work with any broker? What if I'm trading on Chinese exchanges, would your software be compatible with theirs? Many thanks, Sierra Chart Support |
[2017-07-11 04:03:01] |
No, not any broker. In the case of Chinese exchanges the only possibility of support for those would be through Interactive Brokers. Refer to: Interactive Brokers Trading Service Check with Interactive Brokers to see if they have support for the particular exchanges you trade on. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
