Date/Time: Tue, 08 Sep 2026 20:05:22 +0000
Automate a stop with a manual limit order once the order is in a trade
View Count: 1999
[2017-07-10 19:50:32]
Joel Wisdo - Posts: 15
I am trying to set a stop automatically once the limit order enters a trade. The orders on the DOM are manual limit orders. Once one of the manual orders enters a trade I would like to automatically set a stop based on a predefined stop price from point of entry. Any suggestions?
Date Time Of Last Edit: 2017-07-10 19:50:59
[2017-07-10 19:55:12]
This is done through Attached Orders:
Attached Orders
[2017-07-10 20:40:27]
This issue I am running into is that the attached stop order initiates once the orders are manually placed on the chart. My client places manual orders. I am trying to write a piece of code that will launch a stop order (or a "buy / Long" or "sell / short' order depending on the entry) once one of the manual placed orders enters into a trade. I am then looking to modify that stop order based certain criteria. I apologize for my ignorance here. I am new to Sierra Chart and trying to get us to all the functions. It's a complex piece of software so it is taking me sometime to learn it. I think I have the modification done but I am having trouble automating the stop order.
[2017-07-10 20:45:23]
I am using s_ACSTrade to pull info from the entry to find the stop price from the entry point. Here is my code to initiate the stop order. It launches a sell order also though. I guess the easiest way to maybe approach this is to launch a "sell" if the trade is an "buy" but for some reason the code will not launch a "sell" order. Is there something in the sc.defaults that will allow this? Remember there is are 2 manual orders on the DOM. 1 Limit Order and 1 Working Order.
HardStop = CurrentPrice - (AdjustStop.GetInt() * sc.TickSize);
s_SCNewOrder NOrder;
NOrder.OrderQuantity = OrderQuantity.GetInt();
NOrder.AttachedOrderStop1Type = SCT_ORDERTYPE_STOP;
NOrder.Stop1Price = HardStop;
NOrder.InternalOrderID2 = Stop1ID;
int Result = sc.SellEntry(NOrder);
[2017-07-11 04:02:16]
No, it does not work this way. The Stop order is actually in a pending state and only becomes active once the parent order fills. Attached Orders: General Management of Attached Orders
You do not need to make this complicated. You will want to use the Attached Order functionality. It will do what you want.
