Date/Time: Wed, 15 Jan 2025 15:36:46 +0000
Multiple Chartbooks
View Count: 701
[2017-07-10 19:37:35] |
markuz - Posts: 90 |
If I have multiple chartbooks open and detached charts in each chartbook is there any way to keep the detached charts present as i toggle from 1 chartbook to the next? Currently as i toggle from one chartbook tab to the other my detached charts disappear. |
[2017-07-10 19:59:27] |
Yes. Refer to: Detaching and Attaching Chart Windows: Setting Detached Chart to Always Be Visible Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
