Date/Time: Wed, 15 Jan 2025 15:32:29 +0000
Repeating candle issue on NQ 34 Tick chart
View Count: 979
[2017-07-10 18:44:33] |
infpz - Posts: 826 |
Delete/download does not solve; issue is present on one device and not the other. Any suggestions?
Attachment Deleted. |
[2017-07-10 19:04:25] |
Refer to this section about this: Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent: Repeating Bars with Number of Trades or Volume Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
