Date/Time: Wed, 15 Jan 2025 15:47:51 +0000
My Sierra Chart keep saying waiting to connect but doesn't connect what do I do
View Count: 727
[2017-07-10 15:05:36]
User392737 - Posts: 1
Reading Internal Order ID file. | 2017-07-10 10:14:14
Reading Trade Orders file. | 2017-07-10 10:14:14
Reading Trade Positions file. | 2017-07-10 10:14:14
Listening on UDP port 22903. | 2017-07-10 10:14:14
Software version: 1580 | 2017-07-10 10:14:14
Uses New Spreadsheets | 2017-07-10 10:14:14
Usage end date: 2017-07-23 | 2017-07-10 10:14:14
Enabled for: Advanced Features. | 2017-07-10 10:14:14
Enabled for: Advanced Features 2. | 2017-07-10 10:14:14
Enabled for: Sierra Chart Historical Data Service. | 2017-07-10 10:14:14
Allow Support for Sierra Chart Data Feeds is enabled. | 2017-07-10 10:14:14
Current selected Data/Trading service: Rithmic Trading | 2017-07-10 10:14:14
Chart Update Interval: 500 | 2017-07-10 10:14:14
Data/Trade Service Settings automatically set. | 2017-07-10 10:14:14
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-07-10 10:14:14
2017-07-10 10:14:20 Local computer time | 2017-07-10 10:14:14
2017-07-10 14:14:20 Local computer time in UTC | 2017-07-10 10:14:14
2017-07-10 10:14:20 Local computer time in SC Time Zone | 2017-07-10 10:14:14
2017-07-10 14:14:14 Server time in UTC | 2017-07-10 10:14:14
Local computer UTC time and Server UTC time difference: 3 seconds. | 2017-07-10 10:14:14
Program path: C:\SierraChart\ | 2017-07-10 10:14:14
Data Files path: C:\SierraChart\Data\ | 2017-07-10 10:14:14
OS Version Number: 10.0 | 2017-07-10 10:14:14
Locale Setting: C | 2017-07-10 10:14:14
Checking for new symbol settings for service code rim | 2017-07-10 10:14:14
HTTPS connection to www.sierrachart.com:443 (3) | Creating socket. Using TLS 1.2. | 2017-07-10 10:14:14
HTTPS connection to www.sierrachart.com:443 (3) | Connecting to IP: 204.15.192.108. | 2017-07-10 10:14:14
Symbol settings are up-to-date for rim | 2017-07-10 10:14:21
Rithmic Trading | Port for executable: 38040 | 2017-07-10 10:38:33
Listening socket (1156), port 38040 | Closed. | 2017-07-10 10:38:33
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-07-10 10:38:33
Rithmic Trading | Connecting to the server 127.0.0.1. Port 38040 | 2017-07-10 10:38:35
DTC Client (78) | Creating socket. | 2017-07-10 10:38:35
DTC Client (78) | Connecting to IP: 127.0.0.1. | 2017-07-10 10:38:35
Rithmic Trading | Connected to server. | 2017-07-10 10:38:35
Rithmic Trading | Starting socket receive thread. | 2017-07-10 10:38:35
Rithmic Trading | Sending Encoding Request to server | 2017-07-10 10:38:35
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-07-10 10:38:35
Rithmic Trading | Sending logon request message. | 2017-07-10 10:38:35
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-07-10 10:38:35
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-07-10 10:38:35
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-07-10 10:38:35
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-07-10 10:38:36
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-07-10 10:38:36
Rithmic Trading | Received logon response. | 2017-07-10 10:38:36
Rithmic Trading | Server Name: DTC Bridge. | 2017-07-10 10:38:36
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-07-10 10:38:36
Rithmic Trading | Logon error received from server | 2017-07-10 10:38:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-07-10 10:38:36
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-07-10 10:38:36
DTC Client (78) | Initiating close of socket by core. | 2017-07-10 10:38:36
Rithmic Trading | Disconnected. | 2017-07-10 10:38:36
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-07-10 10:38:36
DTC Client (78) | Shutdown started. Waiting for graceful close. | 2017-07-10 10:38:36
DTC Client (78) | Socket gracefully closed by remote side. | 2017-07-10 10:38:36
DTC Client (78) | Closed. | 2017-07-10 10:38:36
Date Time Of Last Edit: 2017-07-10 16:42:04
[2017-07-10 17:02:40]
This is the relevant message:
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-07-10 10:34:39
Refer to:
Rithmic Trading Platform Service: Permission Denied Resolution Procedure
