Date/Time: Wed, 15 Jan 2025 15:25:32 +0000
Color Bar - Scale
View Count: 700
[2017-07-10 13:45:56]
User104854 - Posts: 457
I have a color bar that I use and when it triggers it puts a symbol 2 ticks above the high or 2 ticks below the low. When I scale my chart to automatic I am not able to see these if they happen to be at the high or the low of my chart. Is there a way to adjust a setting so that when I use an automatic scale then it scales the chart to show these symbols? Thanks.
[2017-07-10 17:24:57]
Yes. Use Interactive Scale Range to expand the range of visible prices:
Chart Scale and Scale Adjusting: Interactive Scale Range - Expand/Compress Scale
[2017-07-10 19:40:29]
I know that I can adjust the scale manually to see beyond the price. I guess my question is this:
When the automatic scale setting is used it uses the price for the upper and lower range. Is there a way to include an indicator like a moving average so that when the automatic setting is used it includes the indicator as well? It seems like I've done it before by going into the scale settings within the indicator that I want and clicking on 'same as region' or something like that but I can't remember. Thanks.
[2017-07-10 19:56:13]
Yes, just make sure the Moving Average study has a Scale Range set to "Automatic".
