Date/Time: Wed, 15 Jan 2025 16:19:25 +0000
Custom Study Alert formula
View Count: 1408
[2017-07-10 13:08:07]
User92311 - Posts: 11
We are a propfirm, and one of our senior traders is building a new trading system based on the SC repulse indicator through the study alerts field.
He was able to come up with a formula which is made of 2 separate parts/conditions. When he writes the 2 conditions as two separate strings, the alerts work, when he puts them both together in the same string (as it should be) he gets a syntax error. Here is the formula:
=AND(OR(CROSSFROMABOVE(ID4.SG3[-1],ID1.SG1[-1]),CROSSFROMABOVE(ID4.SG3[-2],ID1.SG1[-2])),(ID4.SG4>ID1.SG1,ID3.SG1[0]>ID3.SG1[-1],ID3.SG1[-1]<ID3.SG1[-2]))
We would appreciate if somebody could tell us what he's doing incorrectly and how to combine the 2 conditions together.
Thank you,
Savius
[2017-07-10 14:34:49]
Use this:
=AND( OR( CROSSFROMABOVE(ID4.SG3[-1], ID1.SG1[-1]), CROSSFROMABOVE(ID4.SG3[-2],ID1.SG1[-2]) ), ID4.SG4>ID1.SG1, ID3.SG1[0]>ID3.SG1[-1], ID3.SG1[-1]<ID3.SG1[-2] )
[2017-07-12 17:45:53]
This seems to work, we will test and see. May we ask the logic of the extra space after/before the parentheses, we were not familiar with that nuance.
Thank you again.
[2017-07-12 19:06:01]
This just makes it more easy to read.
