Date/Time: Sun, 24 Nov 2024 00:03:35 +0000
ZB Roll
View Count: 1511
[2013-08-29 17:47:49]
infpz - Posts: 826
Any suggestion for how to get this chart to look correct? This study needs 50 or so days to calculate correctly and display. When shown on a regular ZBZ3 Chart with less than 50 days to load, the study does not even show up. When I make it continuous, the attached photo is the result.
image2013-08-29_1245.png / V - Attached On 2013-08-29 17:46:22 UTC - Size: 37.57 KB - 467 views
[2013-08-29 18:36:24]
This is what we see for the ZB daily continuous chart:
http://www.sierrachart.com/image.php?l=1377801353200.png
Are those daily bars in your chart image?
[2013-08-29 18:42:41]
infpz - Posts: 826
Sorry for not clarifying, my chart is an intraday chart.
[2013-08-29 22:26:17]
The only solution is to back adjust the data for the prior contract month by using the Adjust Data function:
http://www.sierrachart.com/index.php?l=doc/doc_AdjustingData.html
It will be necessary to open a chart for the ZB September contract to do the adjustment there first. After that the continuous futures contract chart can be reloaded by selecting Chart >> Reload and Recalculate.
