Date/Time: Wed, 15 Jan 2025 15:29:36 +0000
DTC - Sub Instance | Connection error: Connection to self not allowed.
View Count: 611
[2017-07-09 23:01:13]
user8888 - Posts: 159
I'm now getting this message. It was working fine until few hours ago. The only thing I did was upgrade SC to 1580 and downgrade it back to 1575, the same release I was using previously. Now I can't start the 2nd instance.
Thanks for your help.
[2017-07-10 00:01:42]
Provide a copy of the Message Log by following these instructions:
[2017-07-10 00:13:18]
ok,
I attached as well the log of the 2nd instance because there is an additional error there
Private File
Private File
[2017-07-10 00:39:16]
Restart both instances of Sierra Chart. This is now resolved.
[2017-07-10 00:41:44]
Great. Indeed it is. Thanks much
[2017-07-10 04:24:30]
The next release has a change which will prevent this kind of issue from happening again.
