Date/Time: Wed, 15 Jan 2025 15:28:05 +0000
apple historical data
View Count: 993
[2017-07-09 16:51:16] |
Jeliman - Posts: 16 |
Hello, I have a little problem. if i want to load historical data for Apple stock from year 2006 to 2011 at bar period 240 min it shows me nothing - only black screen. from year 2012 it works correctly and if i want to load data at 1 day bar period, i will recieve data from 2006 withnout problem. Could you help me please? thanks in advance. Best regards Jan Stefina |
[2017-07-09 17:44:40] |
I have the same problem with year 2016. When I fill "USE DATE RANGE" from 2016-01-01 to 2016-12-31 for 240 min bar period it loads data from beginning year of 2016 to date only 2016-05-04, so it is not a full year. thx
Date Time Of Last Edit: 2017-07-09 17:46:03
[2017-07-09 18:20:00] |
The answer to post 1 is that the Intraday data you require is not available. When you set Chart >> Chart Settings >>Use Date Range >> To to 0, then what is the last date in the chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-10 18:48:28] |
hello thank you for your response, if I set date range to "to 0" from 2010-01-01 at 240min bar period so the chart starts in 2012-12-27 and it ends in 2017-12-27. how can I get historical data between year 2006 and 2011 for 240 min bar period? I thought that my package5 includes those data. thx J. Date Time Of Last Edit: 2017-07-10 18:48:53
[2017-07-10 19:51:34] |
. how can I get historical data between year 2006 and 2011 for 240 min bar period? I thought that my package5 includes those data We have checked and the Sierra Chart Historical Data includes data back to 2008-05-05 for AAPL.Follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data and it ends in 2017-12-27 This is a future date. There cannot be data available for a future date. Are you at least able to see data to the present time today for the symbol?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-10 19:53:09
