Date/Time: Wed, 15 Jan 2025 15:20:45 +0000
Russell
View Count: 741
[2017-07-08 07:23:57] |
User681267 - Posts: 16 |
Seems to be an issue with Russell data: http://www.sierrachart.com/image.php?Image=1499521705533.png Date Time Of Last Edit: 2017-07-08 18:57:11
[2017-07-09 06:32:16] |
We will correct the expired futures contract data Sunday evening.
[2017-07-09 19:46:23] |
We have corrected the decimal point position for the previous four contracts for the Russell 2000 futures. Re-download the data following these instructions here: https://www.sierrachart.com/index.php?page=doc/ContinuousFuturesContractCharts.html#ReDownloading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
