Date/Time: Wed, 15 Jan 2025 15:39:52 +0000
Pivots alerts
View Count: 707
[2017-07-08 04:18:30] |
Yamin2000 - Posts: 31 |
i found this in the forum but its not working for me. AND(H[-1]<ID1.SG3, H>=ID1.SG3) i want to get alert when the price of the stock reach support lvel 1 .and is it possible to get alert before it reach the support for example 1$ |
[2017-07-08 14:54:38] |
File attached
[2017-07-10 18:17:02] |
Use this formula: =CROSSFROMABOVE(L, SG3) and is it possible to get alert before it reach the support for example 1$
Yes. You would need to first do this calculation using the Study Subgraph Subtract study by subtracting 1 from the S1 Subgraph and then put the alert formula on that study. Refer to:Using the Basic Arithmetic Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-10 18:18:06
