Date/Time: Wed, 15 Jan 2025 15:44:55 +0000
sc.GetStudyArray does not pull historic data from the array refreenced
View Count: 594
[2017-07-07 01:01:31] |
JawilliES - Posts: 1 |
For some reason sc.GetStudyArray does not pull the historic data from the array referenced. It is only pulling data from the time I add the study moving forward. For example if I put the study on at 1:00pm on 7/6/2017 it starts to pull the array data at 1:00pm 7/6/2017 and the previous data is 0. When I remove the study that references the array and re add the study it goes back to 0. Is there a away to pull the data from the array prior to the time / date I add the study?
[2017-07-07 01:58:58] |
Either there is some misunderstanding or programming error on your side, or this is due to a calculation precedence/order issue. Refer to: Chart Studies: Study Calculation Precedence And Related Issues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
