Date/Time: Wed, 15 Jan 2025 15:23:30 +0000
space on top and bottom
View Count: 689
[2017-07-06 22:23:48] |
User968625 - Posts: 260 |
Where can I find the setting to set up the space above the candlesticks. similar to the lock space on the right of the chart
[2017-07-07 02:03:04] |
For space above and below the chart bars you need to use Interactive Scale Range. Refer to: Chart Scale and Scale Adjusting: Interactive Scale Range - Expand/Compress Scale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
