Date/Time: Wed, 15 Jan 2025 15:55:27 +0000
Again half take profit realized
View Count: 892
[2017-07-06 19:23:51]
User1193154 - Posts: 54
Dear engineers,
again occurred same half take profit realized!
Ty
imageScreen Shot 07-06-17 at 09.20 PM.PNG / V - Attached On 2017-07-06 19:23:16 UTC - Size: 159.31 KB - 275 views
imageScreen Shot 07-06-17 at 09.21 PM.PNG / V - Attached On 2017-07-06 19:23:22 UTC - Size: 155.8 KB - 275 views
[2017-07-06 19:25:43]
errata corrige:
this is right image
Had changed quantity, sorry
imageScreen Shot 07-06-17 at 09.24 PM.PNG / V - Attached On 2017-07-06 19:25:18 UTC - Size: 159.32 KB - 270 views
[2017-07-09 13:18:30]
The question remain unexplained...
Have to give up to 300$? (2 x 15 points on Crude oil)
Cheers,
Flavia
Date Time Of Last Edit: 2017-07-09 13:20:51
[2017-07-10 04:25:01]
To be able to answer the question, we need the information requested here:
Trade Activity Log Analysis: Support Assisted Trade Activity Log Analysis
Date Time Of Last Edit: 2017-07-10 04:25:25
[2017-07-10 06:24:42]
hope this helps.
Regards,
Flavia
Date Time Of Last Edit: 2017-07-10 14:35:44
Private File
[2017-07-11 06:40:19]
We need to know the Internal Order ID number also of the order to look at.
Date Time Of Last Edit: 2017-07-11 06:40:31
[2017-07-11 09:00:58]
found this.
attachmentTradeStatistics.txt - Attached On 2017-07-11 09:00:50 UTC - Size: 2.66 KB - 409 views
[2017-07-11 21:43:25]
That is not what we need.
Anyway, how do you have this option set:
https://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#AdjustAttachedOrders
Is it enabled or disabled?
[2017-07-11 22:35:33]
Just now flagged some optioin.
Hope is correct.
Ty
imageScreen Shot 07-12-17 at 12.15 AM.PNG / V - Attached On 2017-07-11 22:35:28 UTC - Size: 28.97 KB - 240 views
[2017-07-12 05:16:08]
If you just enabled Adjust Attached Orders to Maintain Same Offset on Parent Fill, then that will solve the problem.
So at this point we are not going to examine the Trade Activity Log. Just let us know if you have the issue again.
