Date/Time: Wed, 15 Jan 2025 15:32:19 +0000
Horizontal lines and candlestick size/location
View Count: 815
[2017-07-06 16:37:52] |
User968625 - Posts: 260 |
This might be a general question but the case I am having now is with Horizontal lines I am having trouble as when I add levels the candlestick become so small to accommodate these levels while I want the candles to be the main part of the chart and only see the levels when the price is close to them. This will probably apply to other cases like Auto Retracement/projection where for example I might want to always see the 50% (understating that this might effect the candles location) but not the 100% |
[2017-07-06 16:45:44] |
Are you using the Horizontal Lines study?
[2017-07-06 17:31:08] |
Yes, that's my focus now, however, I am also trying to understand in general how does that work/configured with studies like the like Auto Retracement/projection
[2017-07-06 18:57:24] |
To accomplish what you want is explained in this section here: https://www.sierrachart.com/index.php?page=doc/Scaling.html#BasingScalePriceBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-06 22:24:47] |
Thank you, got it to work. you guys gave a really powerful platform but need to learn all these tricks
