Date/Time: Wed, 15 Jan 2025 15:25:57 +0000
Repeating "dings"
View Count: 709
[2017-07-06 14:10:01]
BenjaminR - Posts: 170
This morning on my TPO chart(using version 1568), when I put letters into their own columns on a profile using the context menu, the "ding" or tone repeats many times before it stops. Previously it would "ding" only once. Also, I have a countdown timer study on my TPO chart that is set to "ding" once on the 30 min bar period. When it goes off, it also repeats many times.
Since I just recently updated to 1568, I wondered if possibly this was a bug, so I checked to see if there was another update,and I installed version 1580; however, I still have the repeating "dings".
Using Win 7.
Thanks,
Ben
[2017-07-06 15:40:32]
This is actually the reason for the problem. You cannot use this Countdown Timer study with a TPO Profile Chart. It will not completely function correctly.
You need to use this Countdown Timer study on a separate bar chart with the bars set to 30 minutes each.
Date Time Of Last Edit: 2017-07-06 15:41:34
