Date/Time: Wed, 15 Jan 2025 15:47:31 +0000
ATChart vs Sierra Chart
View Count: 2255
[2017-07-06 13:26:49] |
David - - Posts: 11 |
Dear, In my search for not only the best charting software, I am also searching for a good broker. One the companies which I have come across, Cannon Trading, offers what they call their version of Sierra Charts called ATCharts. Could you please tell me if there are difference between ATCharts and Sierra Charts, and if so what the main differences are? While I do not mind paying directly to Sierra Chart, it would not be smart if I can get the same for free via my broker. Many thanks in advance. David |
[2017-07-06 18:46:59] |
There are limitations with the Sierra Chart provided by a TransAct broker. It does not include the Sierra Chart Historical Data Service. It does not include the Chart DOM or Trading DOM. It does not include the real-time Forex or CFD data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-07 14:58:24] |
ktfroy - Posts: 85 |
Is it possible to trade through a transact broker and enable Sierra via subscription for use of the DOM? Sierra DOM is much preferable.
[2017-07-07 15:04:31] |
Yes. You just need to use your own direct account: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-07 17:10:20] |
What is the monthly cost to add access to the Sierra DOM?
[2017-07-07 18:14:40] |
For Sierra Chart pricing, refer to this page: Description of Service Packages and Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-07 18:35:34] |
I saw that - would that be Service Package 3?
[2017-07-07 20:23:24] |
Yes service package 3. And there is a discount when paying for multiple months.
[2017-07-10 16:05:04] |
Is it possible to trade live with the 2 week trial?
[2017-07-10 17:11:22] |
Yes.
[2017-07-10 18:08:23] |
I am unable to execute and get this error: https://www.screencast.com/t/eau5nIo4INah |
[2017-07-10 18:21:57] |
Contact your broker and have them request us to activate trading for your Sierra Chart account.
