Date/Time: Wed, 15 Jan 2025 15:44:21 +0000
Inquiries for sierra charts
View Count: 676
[2017-07-06 02:57:07]
User157806 - Posts: 71
Few questions if possible to do within Sierra charts.
Attached are some screenshots. Photos are numbered 1-5, I will refer to the number for ease.
Photos:
1. Comes from MT4. Drew a basic Trendline. Right click and the Properties Box Opens I then can type in Name. In the case Recent High.
2. Now you can see the Trendline that was drawn, but no visible text.
3. When you hover over the Trendline the Text that was created momentarily appears, then disappears. Always remains as long as Trendline is there.
4. Data Window appears easily, no crosshairs like Sierra.
5. Need ability to create Hi/Lo Box for specific time periods daily. Typically used on a 15-minute chart.
image1 Trendline Text.JPG / V - Attached On 2017-07-06 02:55:33 UTC - Size: 43.61 KB - 247 views
image2 Hidden Text.JPG / V - Attached On 2017-07-06 02:55:43 UTC - Size: 16.65 KB - 283 views
image3 Trendline is Visible.jpg / V - Attached On 2017-07-06 02:55:47 UTC - Size: 43.07 KB - 274 views
image4 Data Window.jpg / V - Attached On 2017-07-06 02:55:52 UTC - Size: 285.82 KB - 280 views
image5 Hi-Lo Box Specific Timeframe.jpg / V - Attached On 2017-07-06 02:55:56 UTC - Size: 149.52 KB - 299 views
[2017-07-06 18:41:58]
1, 2, 3. It is possible to set text on a Line drawing but it will always remain until removed. Refer to:
Chart Drawing Tools: Modify Text
4. For this use the Chart Values tool and the Compact Tool Values Window. Refer to:
Chart Drawing Tools: Chart Values/Crosshair
Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools
The Chart Values tool has many configuration options and you can set it to not display the vertical and horizontal crosshair lines.
5. Use the Rectangle drawing tool:
Chart Drawing Tools: Rectangle | Extending Rectangle | Ellipse | Triangle
