Date/Time: Wed, 15 Jan 2025 15:41:09 +0000
sc.GetACSDrawingByIndex()
View Count: 725
[2017-07-05 22:13:40]
dtl-saw - Posts: 79
Is this function supported or available?
I don't get it from autocomplete and MSVS2017 says s_sc has no member GetACSDrawingByIndex
Do I need to include another header file?
[2017-07-05 22:58:20]
It is in the very latest version of Sierra Chart.
You will need to update.
[2017-07-05 23:31:08]
dtl-saw - Posts: 79
Can you confirm this function is in the 1580 build?
I just updated to 1580 and this function is not available or I don't see it.
thanks
[2017-07-06 01:39:54]
Version 1580 definitely has this ACSIL function:
You can see it in the SierraChart.h header file.
[2017-07-06 01:46:17]
dtl-saw - Posts: 79
i didn't restart VS after the update. i see the function now, thanks
