Date/Time: Wed, 15 Jan 2025 15:29:39 +0000
Channel Tool with midline
View Count: 2089
[2017-07-05 17:43:50] |
User570089 - Posts: 1 |
Hi, is there something like a channel tool with a 50% or line in the middle? I only see the parallel lines tool. I'm missing this. Should be pretty much a default drawing tool... Thanks.. |
[2017-07-06 04:53:23] |
The Parallel Lines Tool does do exactly what you want: Chart Drawing Tools: Parallel Lines In the Parallel Lines Configuration, you just need to add and enable a 50 % Level. Also make sure the first Level is checked and enabled to be displayed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-06 04:53:40
