Date/Time: Wed, 15 Jan 2025 15:24:09 +0000
DOM issue
View Count: 663
[2017-07-05 14:06:45] |
User99934 - Posts: 227 |
How do I correct the %total misplaced type in attached pic? I would like it placed above all the offers like it used to be. http://www.sierrachart.com/image.php?Image=1499263232223.png |
[2017-07-05 15:51:24] |
This is a problem with the Gain Capital data feed. Reconnect following these instructions: File Menu: Procedure to Reconnect to the Data and Trade Servers For a permanent solution have your broker set you up on CQG instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-05 15:51:33
[2017-07-05 20:42:47] |
We have implemented what we think might be a solution to this. We will try to have a new release out by the morning. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-05 20:43:14
