Date/Time: Wed, 15 Jan 2025 15:33:28 +0000
Your Sierra Chart account type only allows 1 real-time connection.
View Count: 657
[2017-07-05 14:01:52] |
User625195 - Posts: 5 |
Can I have additional real time connection?
[2017-07-05 15:52:46] |
No because RC Order Flow only allows you to have one connection.
